Wall and Windows
Wall and Windows
janus2
Wall and Windows
janus2
Hello!
I am designing some buildings for my model railway.
Now I am looking for a good workflow for walls and windows.
I create a wall and one window. The window consists of the window frame and the cutout in the wall.
When I place the window within an assembly and copy it in a pattern, this works perfectly for the positive elements (window frame), but not for the cutout in the wall. Is there a trick to copying the cutout as well?
Many thanks,
Jan
wersy
You can use the same pattern for faces.
TrippyLighting
Create a positive volume body for the cutout in the window component. And then you can use the combine tool to subtract it form the wall.
There is a very helpful free plugin available on the App store Cut/Join by Component that helps greatly with this workflow.
janus2
Both tips are very helpful.
Thanks a lot
Jan
