View alignment on sketch creation problem
Not sure if this belongs here or in new ideas,
I've noticed that anytime I need to create a sketch, even after the view is positioned where I need it, the view automatically resets to the grid 0,0,0 position on screen instead of where the view was positioned. This means that for every new sketch, no matter if I'm where I want to be drawing, the view moves to zero and I have to pan back to where I was originally. Is this intended or just a work in progress because it's very annoying having to reposition my view for every new sketch added.
For example, I often use a background reference canvas to work from involving many seperate sketch elements and each 'create sketch' reverts to 0,0,0, Can this pleae be fixed so the view position stays where I have it.
This has only started since the auto view aligh feature was added. It's treating every new sketch as though a new view realignment is needed out rather than realizing the sketch plane is already defined and only needs to add geometry rather than a view reset.
josef.kucera
Hi smeggy,
Is this answer what do you want to behave like?
Hope it helps.
Josef
Josef Kucera
Fusion QA
Helmi74
Good to hear you can turn it off - just did that.
The feature kind of disturbs workflows as it often rotates views in the exact opposite direction you would expect it to.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
Yes, thanks.
I like the auto align, it just needed to stop re-centering each time.
