Vertical Text On a Pipe Issue
Message 1 of 15
Hi, I need to write a brand name on my pipe shaped design but unfortunately I can't write vertically. Putting letters one by one is not a wise solution I think. I am using Tinkercad for quick solution (again putting one by one)  but as you know Tinkercad is not as professional as Fusion 360. On the other hand, after putting the letters on the pipe, I need to round their edges that standing on empty space due to pipe curve to create pipe and letters integrity.
What can I do ?
Replies (14)
Message 2 of 15
jeff_strater
can you add some more details here? Are you talking about a vertical string of letters where each letter is itself oriented horizontally? Like: A B C D E F ? If so, then there is no easy way to do this in Fusion today. You'd have to place each letter individually.
Jeff Strater
Engineering Director
Message 3 of 15
jeff_strater
Sorry, the formatting got botched.  I meant this:
This type of orientation is not possible in Fusion today.
Jeff Strater
Message 4 of 15
Yeah something like that. Vertically Brand name for example
B
E
R
K
A
Y
There is no easy way right ? 😞
Message 5 of 15
etfrench
It's not hard to do this, but it does take a few more steps than you would think necessary.
  1. Create the pipe.
  2. Create a sketch for the text.
  3. Project the pipe body to the sketch.
  4. Create a construction line along the center of the pipe axially.
  5. Draw a construction line perpendicular to the center line with one end coincident with the center line for the start point of the first letter.
  6. Use a rectangular pattern with the perpendicular line as the base and the number of letters (including spaces) for the count.
  7. Create the first letter away from the previous geometry.
  8. Draw a short construction line (or a point) starting at the midpoint of the bounding rectangle's bottom edge.
  9. Create a coincident constraint between this line and the first letter location in the rectangular pattern.  This will place the letter centered on the pipe.
  10. Repeat for each letter.
ETFrench
Message 6 of 15
MichaelT_123
Hi Mr Becko872,
No, there is no easy way :-).
Have look at:
https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-wrap-text-around-a-double-curved-su...
and related:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/sketchtext-object/m-p/8562981
How many bikes do you have?
Regards
MichaelT
MichaelT
Message 7 of 15
lichtzeichenanlage
Use Illustrator or Inkscape to create the text, export a e.g. svg file and import it into Fusion 360
Message 8 of 15
etfrench
I'll still say it's easy, just convoluted Smiley Happy
ETFrench
Message 9 of 15
lichtzeichenanlage
Easy - yes. But compared to having the option to press return in a text box.... not efficient.
Message 10 of 15
etfrench
But still faster than having to repairing svg fonts imported from Inkscape Smiley Happy
ETFrench
Message 11 of 15
lichtzeichenanlage
You have a point here. But the question is - does it matter on a pipe?
Message 12 of 15
I got it. Thank you. That makes everything clear
Message 13 of 15
brett2DW85
.svg file created in Inkscape.svg file created in Inkscape.svg file imported into Fusion360.svg file imported into Fusion360
When I try that Fusion 360 gives a warning and converts the text back to horizontal.......any ideas?
Message 14 of 15
etfrench
Why bother with Inkskape when it's so easy to do in Fusion 360?
Simply create a rectangular array of (fully constrained)points, then use the midpoint constraint to move the letters into position. (Note, I use a line and a point in the screencast.  Only the point is necessary.)
ETFrench
Message 15 of 15
luka_mbs
Community Visitor
Community Visitor
BTW... its 2025 now! Fusion is still not able to import that kind of Text from SVG´s correctly, nor is it able to create such text elements...
