Using variable for pattern quantity
Message 1 of 9
I'm attempting to make a rectangular pattern based on the overall dimensions of a face. The distance accepts variables/formulas without issue. The quantity though, acts as if it will accept, bringing up variable names as autocomplete but then does red when I put a variable in. Is this the expected behavior? If so is there a way to dynamically change the number of times a pattern is repeated?
Replies (8)
Message 2 of 9
HughesTooling
It does work but the parameter needs to be unitless so you'll need something like d1/1mm to make a distance parameter unitless. Can you get a screen grab of the dialog with the equation you're trying to enter.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
Oh yeah, I see it now. I'm getting * 1 in tacked onto the end of what should be a unitless variable. Deleting and recreating with the No Units dropdown selected did the trick.
FWIW, that field looks disabled.
Message 4 of 9
patrick.dyke
I was running into this, too. I was trying to divide two lengths to get a count (depth / finger_width). It seems that it only works if the numerator (depth in my case) is a whole number, regardless if the resulting number is a whole number.
Example:
8in/.25in = Worked
7.75in/.25in = Doesn't Work
Even if I put this expression on a unit-less parameter and use that, it still will not accept it if the numerator is not whole.  What did work was adding a rounding function so the the result will always be whole. In my case I used floor: floor(depth / finger_width)
Message 5 of 9
juha.ruhkala
Worked once then moved component under subcomponent and made the pattern there so browser stays bit cleaner.
Now with same parameters can't get it to work.
And if i try to remake it under parent component doesn't work either.
quantity parameter name "Saleita" expression "ceil(( ( SaleverhoLeveys / 1 mm ) - ( SaleikonOsienKorkeus / 1 mm ) ) / ( SaleidenValys / 1 mm ))" gives value 108
distance parameter name "SaleidenValys" expression 22mm
now even editing feature using manual values gives an warning "It's an invalid input setting" and have to delete and remake "pattern on path"
if I manually put an value 108 on the quantity it works even replaced Ä with A but didn't make any difference.
Message 6 of 9
TheCADWhisperer
@juha.ruhkala
You should have started a new discussion thread (and link back to this one for reference).
And
Message 7 of 9
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
Message 8 of 9
juha.ruhkala
Made an parameter with value 20. Then put that parameter in to pattern quantity and it works.
Then made another value with calculation with parameters and added that parameter to the working quantity parameter expression.
Now it works as long as i don't edit pathpattern, If i edit it it'll give a warning and stop working.
First attachment was wrong version
Parameter "SaleverhonKorkeus" changes model height and that allso changes the quantity
ps. I'am new to Fusion 360 and It's my first cad software 🙂
Message 9 of 9
g-andresen
Pattern on path is currently causing occasional problems in connection with variables.
But for this example Rectangular Pattern is better suited.
I have made two small changes in the parameter list.
günther
