Using text ttf font not supported
brendan
Observer Observer
Message 1 of 9
brendan
Observer
Observer
Hi all
trying to use the attached font to make a 3D drawing so i can make an engraving with my CNC machine. but it seems not to be supported.
It has worked for me in Rhino3D
am i doing something wrong?
thanks.
Brendan
Replies (8)
Message 2 of 9
cekuhnen
I do not think that Fusion can load custom fonts and vectorize them.
You need in a vector app create the paths and then export it via SVG
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 3 of 9
junyuan.zhuJ4HVC
Hi Brendan,
Currently there are some fonts which are not supported in Fusion and @cekuhnen has provided a good idea of creating the text file as SVG and import it.
But the Waltograph actually works on my side, please restart Fusion after the installation of the new font.
Thank you,
Sty
Message 4 of 9
junyuan.zhuJ4HVC
Hi Brendan,
This font does not work on Fusion Mac version.
We are logging a bug for this (FUS-26517).
Please use cekuhnen's work-around if you are using Mac.
Thank you,
Sty
Message 5 of 9
brendan
Observer
Observer
hey thanks guys
I am glad that we have identified it as a bug.
Hope its not to long until its fixed.
thanks everyone
Brendan
Message 6 of 9
3 years later bug still persist ;/
Message 7 of 9
jameshorne0503
Does the font show in other apps, I had this problem in the past (on a windows machine though) and was able to put in a command to allow Fusion to see more fonts. https://forums.autodesk.com/t5/fusion-360-design-validate/ttf-font-not-showing-up/m-p/7992278/highli...
Another solution that's been suggested is to try adding the font as OTF: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Cus...
Hope this helps (doubt it does though tbh)!
Message 8 of 9
StephenCim-001
I've had good results on OSX by installing the ttf fonts in the Computer font library ie /Library/Fonts instead of user library, i.e /users/stephen/Library/Fonts
For about 5 years , I was running bootcamp , to boot into windows just so I could use 1/2 dozen .ttf fonts that did not work in OSX, since I moved them to Computer Library all good, boot camp gone 🙂
Message 9 of 9
Thank you! This worked!
