I have an irregular shape made up of separate elements - eventually these will be separate components. I've defined a offset plane using "plane along path" and used that to sketch a rectangular profile at a right angle to the surface of one element. I want to use Sweep to cut away that profile all around the interior. However, Sweep won't allow me to select all the edges to form the path. I only seem to be able to select one edge for the path.
Essentially, I want to cut a recess (I think technically it is called a rabbet) on the bottom, on the inside of this open shape. Any suggestions? Thanks!
