I'm trying to create a cross hatch pattern in Fusion that I'm having some trouble completing. I'm creating a grid in the sketch environment that I can then export as a DXF for 2D cutting. I was wondering if one of you Fusion wizards could post a Screencast of how you would do it. I have watched a couple video from Lars C but have not quite seen what I'm looking for. I can get the lines going in one direction but when I try to do the same thing in the other direction it doesn't work and I also get it crashing a lot. I've posted an image of what I have with half of the lines done to you can see what I'm trying to do.
Thanks in advance.
Solved by jeff_strater. Go to Solution.
Solved by phil_eichmiller. Go to Solution.
I doubt Fusion is crashing. This kind of thing just causes a longer compute cycle. Fusion will be unresponsive for events like that.
PS: If this is the pattern you are trying to make: To make the grid lines in the other direction, edit the sketch, draw a line going the direction you want it to go, then pattern it x110.
Fusion is going to struggle with that many lines in a sketch pattern. When you say Fusion is crashing, do you see a crash report? Or are you force quitting? My guess is the latter. I suspect if you just let it run long enough, it will succeed, but it will take a VERY long time, and will be impossible to work with afterwards. This kind of patterning is not recommended in Fusion sketch. In general, we recommend patterning faces or features of a solid rather than in a sketch. If you are really just creating 2D geometry to export to DXF and are not planning to create a solid, Fusion may not be the tool for you. You could make an artificial solid, pattern those lines in the solid, sketch on the top face and export that as a DXF, but that workflow is not great, either.
Hi Phil,
Yes, to be accurate I misspoke to say that Fusion crashed. Rather, as Jeff stated and you mentioned I was waiting for a long period of time and then getting a "program is unresponsive" warning and then quitting. In this case, I don't need it to calculate a profile as I'm just trying to create a 2D toolpath so I will uncheck that option and try it again. Thanks for your help on this.
