Hi all, I was hoping to get help with a problem I'm having using the project to surface command.
I'm trying to create a pattern that wraps around the body, so that all 4 sides will be connected and even, so that I can extrude these sections.
My goal is to have a section like this:
After using the project to surface command, I end up with this sketch, which is theoretically exactly what I want. However, I can't seem to use these lines for anything practical, like extrusion, cutting etc.
The segment of the sketch projected onto the flat face parallel with the sketch plane can be selected just fine:
However, when I go to click on the other segments of the sketch, it won't allow selection; it just selects the face instead.
Any ideas on how to approach this problem? Alternatively, if project sketches isn't the way to approach this problem, any alternative methods?
Thanks!
