using interference to create new bodies
I'm trying to remove an interference from two components. I can't seem to check the check box to keep the interference body, which I'm hoping to use to cut (or subtract) out of one of the components.
Is that a doable workflow?
Matt
TrippyLighting
The "Interference" tool is n the"Inspect" menu which only contains analysis tools.
You would want to use the "Modify-.Combine" tool with the appropriate selection (join, cut, intersect) to actually modify your geometry.
that's it!
Thanks trippylighting. much appreciated.
Matt
