Using Dimensions In An Equation
garmitage
garmitage
I am unable to find any useful information about the ability to create an equation in a sketch dimension by selecting more than one of the other sketch dimensions.  If that still isn't possible, is there an easy way to pull up what a dimension's "name" is?
JamieGilchrist
hi garmitage,
yes you can absolutely do this.
in this short clip, hovering over the dimension for a moment reveals the dimension name (d1, d2, etc...)
then type the dim name (you can click on the dim you want to use) and the rest of your equation.
this is the most basic example here.  You can get more complicated using parameters.
here is a more detailed example
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
etfrench
You can manually enter multiple dimension references , but you can only enter by clicking on one once.  Clicking on a second dimension returns the first clicked dimension.
ETFrench
TheCADWhisperer
@etfrench wrote:
...  Clicking on a second dimension returns the first clicked dimension.
wow
TrippyLighting
Yep, I've reported that a while ago. It's another concept that was not fully thought through when it was implemented.
