Using 3DS Max files in Fusion 360 design
ylevine
ylevine
I have files created in 3DS Max (from Autodesk). I'm trying to use them in a Fusion 360 design and make solid bodies from them, but havig trouble. I am able to import them from some intermediate file formats, but when I try to convert the mesh to something useable in Fusion 360, I get this error message:
Please help! Thank you!
Yehoshua Levine
Levine Innovations LLC
yl@levineinnovations.com
TrippyLighting
Whatehr that works depends on what sort of mesh you intend to import. Post a screenshot of the mesh and we'll see.
In general 3DS Max is a mesh and subdivision surface modeler. If you have a control mesh that consists of quads then this may work.
Fussion 360 needs makes solids or T-Splines, with the latter one needing the quads.
ylevine
Here's the screenshot. I can only show you part to preserve confidentialy.
Yehoshua Levine
TrippyLighting
Hmm... I am assuming you do not want to keep this triangulated faceted look but want a smooth body ?
I Don't work with 3DS Max but I know Blender , which has a tris to quads function that does a great job of converting triangulated meshes to quad meshes. Of course I cannot see your entire mesh so it is hard to judge whether this would work but if 3Ds Max has such a function the I'd use that and then export the quad mesh to .obj.
Then that obj would be Imported into Fusion 360 and there it would be converted into a fully editable T-Spline body with no loss of fidelity.
I' ve asked this before, was this designed in 3ds Max as a subdivision surface ?
the control meshes for subdiv surfaces usually are all-quad surfaces and are easy to export/import in to Fusion 360. I've done this several times between Blender and Fusion 360 and it works beautifully.
innovatenate
Autodesk Support
Autodesk Support
There's a tool in 3DS Max that will allow you to "Quadrify" a triangle mesh. You may consider testing this and seeing if you get better results. The below forum discussion this and a detriangulate script you may find useful.
http://forums.autodesk.com/t5/modeling/is-quadify-mesh-detrianglulate-script/td-p/4185433
Hope this helps!
Nathan Chandler
Principal Specialist
