User Parameter not saved in pattern's distance field
SGoldthwaite
SGoldthwaite
In the pattern operation, I can enter a user paremeter for the distance, but it's not saved.  Fusion convert the parameter or formula to a value.  It doesn't do this on the quantity field, that works okay.
See screencast:  http://autode.sk/1RYAHLh
NicolasXu
Hi SGoldthwaite,
Good catch! Thanks for recording the screencast to show the problem.
It seems only happen to the pattern of spacing type. I can reproduce it and have asked the development team to look into it for a fix. (Report No. is FUS-21939, in case for future references).
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
thuje13
Any news on this? I'm struggling with the same problem right now..
You can go into Modify -> Change Parameters, find needed ..Pattern-..Distance (i had R-Pattern1-uDistance) in Model Parameters, and insert you expression for distance there. That way it worked for me
