Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I want to use a sketch ("ergots") and extrude it "joined" to one component (CASE BOTTOM), but use the same sketch and extrude "cut" to another component(CASE TOP). I put the sketch in the main file and expect to extrude it by selecting the component but I can't select it (actually I can't even extrude when selecting source tree).
I guess I am not using the right workflow but I don't know how to do.
Thanks for your help.
Solved by jhackney1972. Go to Solution.
Please attach your model. If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Edit the sketch "ergots"and toggle the "Profile" check box in the Sketch Palette off and on. For some reason the profile will not show up until you do this. The rest is down-hill. I have attached your model with a 4 mm symmetrical extrusion, one cut and one join as requested.
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
