Upper part model
Upper part model
nubrandao
Upper part model
nubrandao
Hi, Im trying to find a model of a upper part só i can replicate the Machine strategy from this powermill video
I want to Machine the same part but in Fusion and make a video to show at company
If someone have a upper part model identical to this i apretiate
@nubrandao - this post has been edited due to Community Rules & Etiquette violation.
kacper.suchomski
Hi
I don't want to be pessimistic, but the arms industry is a very expensive business and I doubt anyone would even go public with it (outside of the official business), let alone share it.
Nevertheless, the geometry isn't particularly complicated and if you sit down with it you should be able to model it to a satisfactory degree (for presentation purposes) in an evening.
Good luck
Kacper Suchomski
andy_woodward66
Have you tried GrabCAD? Loads of models on there...
@andy_woodward66 - this post has been edited due to Community Rules & Etiquette violation.
nubrandao
I dont want a full model, just the upper part
Because Im trying to Machine in Fusion and is complicated, i want to achieve a good result
andy_woodward66
I get that. However, a lot of the better designed models on GrabCAD are comprised of all the constituent parts, each with a separate model. This may not be immediately obvious when you look at the render on GrabCad.
You need to download a model first, then open it in Fusion to ascertain whether each component has been modeled individually.
Needless to say, you need the downloadable model to be in a Fusion compatible format.
