I have a 3D STEP model I'm using to create an enclosure. I used this model to create cutouts in my enclosure and, while modelling the box found that I had to make some changes to the PCB to get it to fit properly.
I updated the PCB and updated the component, which worked fine.
However, my flow is broken in a bunch of places now because I used the model to project the cutouts and fusion is saying "failed to get target occurrence transform".
The location of the connectors hasn't changed - only the PCB dimensions were updated.
I'm wondering if there is some way to "reconnect" the projections from the component or do I have to recreate the projection every time I update the PCB?
new to this 3D design stuff, so any help appreciated.
