Update a drawing's template
MSE_Mech_94
MSE_Mech_94
Curious to know if there is a way to update a drawing's template once the drawing has been created.  I have created a drawing using a custom template.  After making that drawing, I updated the custom template.  The drawing does not reflect the new template.
Thanks for any insight, help or suggestions you may have.
Best Regards,
F. Gant
HughesTooling
I guess once the template's inserted it's not linked to the external template design, have you tried inserting the title block again from the bottom toolbar.
Mark Hughes
Owner, Hughes Tooling
MSE_Mech_94
Mark,
Thanks for the suggestion.  Yes, I tried inserting a title block.  That option looks for a file on my computer.  I wasn't able to go to the template saved in my Fusion 360 project folders.
Frederick
HughesTooling
If no one comes up with a better idea you might have to open your template, save as a DWG then insert that from your computer.
Mark
Mark Hughes
