Unwanted Position Changes, Joints not behaving
jpvonoy
jpvonoy
I recently made some major updates to my model.  Now there is some undesired position and joint behavior.  If I try to move a slider joint, the positioning of other unrelated components changes.  Also, if I try to Capture Position, it moves all my components around.
I've tried to edit the existing joints and tried deleting them to re-create them, but everything moves right away and I don't want to have to reposition every component again to fix it.
How can I fix this?  See screencast.  I can supply the f3d file privately.
Jeremy
kate.raskauskas
Hi @jpvonoy
Can you please send the file to me so I can take a look?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
jpvonoy
Thanks @kate.raskauskas.  I sent you a PM with a link to the project.
I performed a Compute All and have 2 Warnings and 2 Errors.  I should probably solve these first before wasting your time with my other issue.  I need to do some research on how to fix the errors and warnings.
kate.raskauskas
Hi @jpvonoy,
Let us know if you need help with any warnings/errors!
Kate Raskauskas
jpvonoy
I figured out how to fix my warning and errors, but that did not solve this issue.  @kate.raskauskas, do you still have the PM I sent last month with the project link?  Would you be willing to take a look and help me understand this issue I'm having?
