Unlinking components from circular patterns
justinking30
justinking30
Is there a way to unlink components that were created via the circular pattern tool? I need cut those 4 holes out shown in the screengrab below only in the side that I have tried to extrude through.
Usually I would unfold the part and create the holes that way but I couldn't illustrate my point in the screengrab as well that way.
I have attached the .f3d file.
Thanks in advance.
jhackney1972
Boundary Fill and then Convert to Sheet Metal are the two commands that will transform one side into a new component so your holes can be limited to one side.  You did not indicate if the holes were on the top or bottom ring but you can switch the objects cut by editing the extrusion.  Model attached.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
justinking30
Thanks for the help, that will work.
This seems like a bit of a workaround instead of a solution though. Is there a process that I have done earlier in the design that I may have done differently to end up with the desired result?
jhackney1972
If your remember that a Pattern creates new components that are just like components created with Copy/Paste.  In this case, you can use Mirror instead of a pattern.  Mirror, unlike a pattern, creates a unique component.  Neither of these methods are "workarounds", they are design choices.  I have attached your model using the Mirror process.
justinking30
Thank you for your help.
Apologies, workaround was probably the wrong choice of words.
