Hello! I'm working on making some clay cutters and I've been doing ok with most of my shapes but one is giving me issues when I'm trying to make a tapered angle for the outer blade part of the design. The inner part of the design works without issue, but the outer part gives me an "Unknown error" after I confirm the extrusion with a negative taper angle when I try to extrude it by 3mm and a -7°taper angle despite the preview of the extrusion showing a success.
When I try to extrude 7mm without the taper angle, then add 3mm with a -7°taper angle it doesn't work at all so I'm guessing something isn't right with the model itself but I can't figure out what it could be the cause. I'm pretty new to this program, only used it to make a few dozen clay cutters so I'm not sure what to pay attention to. Any help or tips are very welcome!
I'm attaching a video of the error when I try to extrude it by 3mm and a -7°taper angle, and the .3fd file that I was working with.
