Unexpected Authentication Error Mac
Is there a similar solution to this: http://forums.autodesk.com/t5/design-validate-document/authentication-error/m-p/5884509/highlight/tr...  for OS X?
There's something similar in the info for the app, but I don't know the path where another option would be.
Everything was fine until I crashed.  Now trying to relaunch I'm getting this error.
Tried to reainstall F360 and received:
Unexpected Error
.Please attach the file
autodesk.webdeploy.streamer.log
HughesTooling
Have you tried a private message to @James.Youmatz to see if he has any advice although mentioning him in this thread might be enough to get James involved.
Mark
Mark Hughes
Owner, Hughes Tooling
I just did. Thanks for the suggestion!
James.Youmatz
Autodesk Support
Autodesk Support
Thanks @HughesTooling for helping our users out! You're the best!
He is experencing an error in his log file that is most likely network related (although this happened after a crash which is odd) which is Errno 64: Host Not Found. Thanks and @Anonymous I will go ahead and email you back with my suggestions. Thanks again Mark!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
For the reinstalling error...
Here's the plist info for where the error is pointing (I think), below
is the log of the failure/timeout.
"http://www.apple.com/DTDs/PropertyList-1.0.dtd">
CalSuccessfulLaunchTimestampPreferenceKey
406245632
databaseWasReset
Log file for crash of reinstall:
12/21/15 7:36:14.787 PM Spotlight[918]:
[com.apple.calendar.agentLink.xpc] [Creating a remote proxy object for
com.apple.CalendarAgent.proxy resulted in an invalid connection. The
connection will be removed. Error Domain=NSCocoaErrorDomain Code=4099
"The connection to service named com.apple.CalendarAgent.proxy was
invalidated." UserInfo={NSDebugDescription=The connection to service
named com.apple.CalendarAgent.proxy was invalidated.} (
0 CalendarAgentLink 0x00007fff9186dacd
-[CalAgentLink _remoteObjectWithErrorBlock:] + 47
1 CalendarPersistence 0x00007fff96375575
-[CALIdentityManager resetCache:] + 242
2 CalendarPersistence 0x00007fff96375442
-[CALIdentityManager init] + 146
3 CalendarPersistence 0x00007fff963753a2
__36+[CALIdentityManager defaultManager]_block_invoke + 41
4 libdispatch.dylib 0x00007fff9601933f
_dispatch_client_callout + 8
5 libdispatch.dylib 0x00007fff96019237
dispatch_once_f + 67
6 CalendarPersistence 0x00007fff96375377
+[CALIdentityManager defaultManager] + 42
7 CalendarPersistence 0x00007fff9637532b
-[CalVirtualSource ownerAddresses] + 37
8 EventKit 0x00007fff84e90fbb
-[EKFrozenCalendarSource
initWithObject:createPartialObject:preFrozenRelationshipObjects:] + 476
9 EventKit 0x00007fff84e90db5
+[EKFrozenObject
frozenObjectForObject:createPartialObject:preFrozenRelationshipObjects:forceUpdate:]
+ 176
10 EventKit 0x00007fff84e90ce1
+[EKFrozenObject
frozenObjectForObject:createPartialObject:preFrozenRelationshipObjects:]
+ 60
11 EventKit 0x00007fff84f4c398
-[EKObject
initWithObject:createPartialBackingObject:keepBackingObject:preFrozenRelationshipObjects:additionalFrozenProperties:]
+ 234
12 EventKit 0x00007fff84f51f9b
-[EKSource
+ 110
13 EventKit 0x00007fff84e90c6e
-[EKObject
initWithObject:createPartialBackingObject:keepBackingObject:preFrozenRelationshipObjects:]
+ 74
14 EventKit 0x00007fff84e90bfc
-[EKObject
initWithObject:keepBackingObject:preFrozenRelationshipObjects:] + 104
15 EventKit 0x00007fff84e90b72
-[EKObject initWithObject:] + 84
16 EventKit 0x00007fff84e90b02
+[EKObject objectWithObject:] + 65
17 EventKit 0x00007fff84e90a79
+[EKSource sourceWithCalendarSource:eventStore:] + 73
18 EventKit 0x00007fff84e90a0a
+[EKSource localSource] + 70
19 EventKit 0x00007fff84e9073d
__62-[EKCalendarStoreBackingStore
_doBackgroundInitializationWork]_block_invoke + 113
20 libdispatch.dylib 0x00007fff96024871
_dispatch_call_block_and_release + 12
21 libdispatch.dylib 0x00007fff9601933f
22 libdispatch.dylib 0x00007fff9601d1cf
_dispatch_root_queue_drain + 1890
23 libdispatch.dylib 0x00007fff9601ca34
_dispatch_worker_thread3 + 91
24 libsystem_pthread.dylib 0x00007fff9618b68f
_pthread_wqthread + 1129
25 libsystem_pthread.dylib 0x00007fff96189365
start_wqthread + 13
12/21/15 7:36:14.792 PM Spotlight[918]:
1 CalendarPersistence 0x00007fff963759d8
+[CalPersistence _startCoreDataXPCServer:] + 198
2 CalendarPersistence 0x00007fff96374e2e
+[CalPersistence
setupCalendarPersistence:andCreateDefaultCalendarsIfNeeded:withSetupGroup:]
+ 207
3 EventKit 0x00007fff84e909a7
-[EKCalendarStoreBackingStore _updatePersistenceAvailability] + 85
4 EventKit 0x00007fff84f3acf2
initWithSourceFilters:options:accessRequestedForEvents:accessRequestedForReminders:asyncWithCompletion:orWithExistingStore:]
+ 799
5 EventKit 0x00007fff84f3a99c
initWithSourceFilters:options:accessRequestedForEvents:accessRequestedForReminders:asyncWithCompletion:]
+ 86
6 EventKit 0x00007fff84f32c8f
-[EKEventStore
_newBackingStoreForType:options:sourceFilters:accessRequestedForEvents:accessRequestedForReminders:asyncWithCompletion:]
+ 121
7 EventKit 0x00007fff84e8fe54
-[EKEventStore
_newBackingStoreForType:options:sourceFilters:asyncWithCompletion:] + 81
8 EventKit 0x00007fff84e8fcf8
-[EKEventStore
initWithStoreType:options:sourceFilters:asyncWithCompletion:orWithExistingStore:andBackingStore:]
+ 393
9 EventKit 0x00007fff84e8fb51
-[EKEventStore
initWithStoreType:options:sourceFilters:asyncWithCompletion:] + 86
10 Spotlight 0x0000000102547b77
Spotlight + 404343
11 Spotlight 0x0000000102547c74
Spotlight + 404596
12 libdispatch.dylib 0x00007fff9601933f
13 libdispatch.dylib 0x00007fff96019237
14 Spotlight 0x0000000102547c49
Spotlight + 404553
15 Spotlight 0x000000010253dd95
Spotlight + 363925
16 libdispatch.dylib 0x00007fff96024871
17 libdispatch.dylib 0x00007fff9601933f
18 libdispatch.dylib 0x00007fff9601d1cf
19 libdispatch.dylib 0x00007fff9601ca34
20 libsystem_pthread.dylib 0x00007fff9618b68f
21 libsystem_pthread.dylib 0x00007fff96189365
start_wqthread + 13
12/21/15 7:36:14.793 PM Spotlight[918]: [com.apple.calendar.store.log]
[Tried to connect to XPC persistence, but connection was invalidated,
retrying...]
[Retry Attempt 1]
12/21/15 7:36:14.797 PM Spotlight[918]:
2 CalendarPersistence 0x00007fff96375e6b
+[CalPersistence _startCoreDataXPCServer:] + 1369
3 CalendarPersistence 0x00007fff96374e2e
+[CalPersistence
+ 207
4 EventKit 0x00007fff84e909a7
5 EventKit 0x00007fff84f3acf2
+ 799
6 EventKit 0x00007fff84f3a99c
+ 86
7 EventKit 0x00007fff84f32c8f
-[EKEventStore
+ 121
8 EventKit 0x00007fff84e8fe54
-[EKEventStore
9 EventKit 0x00007fff84e8fcf8
-[EKEventStore
+ 393
10 EventKit 0x00007fff84e8fb51
-[EKEventStore
11 Spotlight 0x0000000102547b77
Spotlight + 404343
12 Spotlight 0x0000000102547c74
Spotlight + 404596
13 libdispatch.dylib 0x00007fff9601933f
14 libdispatch.dylib 0x00007fff96019237
15 Spotlight 0x0000000102547c49
Spotlight + 404553
16 Spotlight 0x000000010253dd95
Spotlight + 363925
17 libdispatch.dylib 0x00007fff96024871
18 libdispatch.dylib 0x00007fff9601933f
19 libdispatch.dylib 0x00007fff9601d1cf
20 libdispatch.dylib 0x00007fff9601ca34
21 libsystem_pthread.dylib 0x00007fff9618b68f
22 libsystem_pthread.dylib 0x00007fff96189365
start_wqthread + 13
12/21/15 7:36:14.797 PM Spotlight[918]: [com.apple.calendar.store.log]
retrying...]
[Retry Attempt 2]
12/21/15 7:36:14.948 PM Spotlight[918]:
3 CalendarPersistence 0x00007fff96375e6b
4 CalendarPersistence 0x00007fff96374e2e
+[CalPersistence
+ 207
5 EventKit 0x00007fff84e909a7
6 EventKit 0x00007fff84f3acf2
+ 799
7 EventKit 0x00007fff84f3a99c
+ 86
8 EventKit 0x00007fff84f32c8f
-[EKEventStore
+ 121
9 EventKit 0x00007fff84e8fe54
-[EKEventStore
10 EventKit 0x00007fff84e8fcf8
-[EKEventStore
+ 393
11 EventKit 0x00007fff84e8fb51
-[EKEventStore
12 Spotlight 0x0000000102547b77
Spotlight + 404343
13 Spotlight 0x0000000102547c74
Spotlight + 404596
14 libdispatch.dylib 0x00007fff9601933f
15 libdispatch.dylib 0x00007fff96019237
16 Spotlight 0x0000000102547c49
Spotlight + 404553
17 Spotlight 0x000000010253dd95
Spotlight + 363925
18 libdispatch.dylib 0x00007fff96024871
19 libdispatch.dylib 0x00007fff9601933f
20 libdispatch.dylib 0x00007fff9601d1cf
21 libdispatch.dylib 0x00007fff9601ca34
22 libsystem_pthread.dylib 0x00007fff9618b68f
23 libsystem_pthread.dylib 0x00007fff96189365
start_wqthread + 13
12/21/15 7:36:14.949 PM Spotlight[918]: [com.apple.calendar.store.log]
retrying...]
[Retried Attempt 3]
12/21/15 7:36:14.980 PM Spotlight[918]: [com.apple.calendar.store.log]
[Couldn't update cached me card from CalendarAgent]
Last night, I was able to completely remove that install of F360 and I perform a reinstall off the Mac App Store.  I am now up and running again.
Few notes:
The Uninstaller will fail if it doesn't find an expected file.  The way it fails is kind of not great.  The Uninstaller gives you a file not found message and an ok button, then quits and deletes itself.  So you can't go back and replace what you moved and re-run it.  Might be nice if it either ignored errors and kept going, or quits and stays after a fail.  I was unable to find a download of just the uninstaller to try a workaround (another nice to have for anyone who is jammed up this way).
It was definitely not a network issue, had to be a corrupted file.  I checked multiple networks, reset routers, checked ports.  (AT&T uverse and over my phone's hotspot with T-Mobile).
Thanks for all your help!
