Uneven fillet on identical body features
kreatronik
kreatronik
Hi there,
I have these 3 profiles generated by a rectangular pattern of the center ellipse.
When I apply a fillet and move the tool arrow back and forth, I noticed this difference and can't comprehend, what's causing that problem.
I already also used the inspect tool to check for slight variations, but they look all the same.
Thanks in advance 🤗
Hannes
user015M86Y
Hi, look at the timeline, there is an offset face of 1 mm to the cavity 3
jhackney1972
In Extrude 4, in your timeline, you accidentally select the bottom of one of the pockets making it thicker which in turn affects the Fillet.
John Hackney, Retired
kreatronik
Thank you, but it was acutally the "Offset Face" command.
