UNC 3/8 inch thread regarding 3D Printing......
burnhamdAAVCD
Message 1 of 8
burnhamdAAVCD
Hello All!
Please excuse my lack of knowledge, I'm working on project with my students where we are using 3/8 inch UNC thread in Fusion360.  My unique problem is we are printing out on a MakerBot Method 3D printer.  In my research I found that PLA material that we use shrinks .20 - .25.  I'm not sure how or if I can scale the area that is threaded.
Thanks!
Dan
Replies (7)
Message 2 of 8
TheCADWhisperer
Message 3 of 8
burnhamdAAVCD
The thread is supposed to be UNC 3/8 - 40.
Thanks!
Message 4 of 8
TheCADWhisperer
Are there any unresolved issues highlighted in yellow in your Timeline?
Are all of your sketches fully defined?
Corrected file with explanation to follow in a few minutes.
Message 5 of 8
burnhamdAAVCD
There are three, and one of them has to do with the thread.
Message 6 of 8
TheCADWhisperer
There is no such thing as a UNC 3/8 - 40 thread.
I think you meant a UNS 3/8-40 thread.
Message 7 of 8
TheCADWhisperer
Examine the Attached file.
The last three features were used to cut additional clearance.
The two Press/Pull features to move the faces of the thread in a bit and the Extrude to cut the root a bit.
Beginners should (almost) never use Splines.  And if splines are used - only very very few points.
I created the thread as Cosmetic.
Added the Chamfer and Fillet and then edited the thread (Hole feature) and changed to Modeled.
Message 8 of 8
burnhamdAAVCD
Awesome thanks so much, I appreciate your time!!!!
Dan
