I just tested that file in a couple different programs (Inventor, Inv. Publisher, Alias, & Showcase) and I am getting failure messages across the board in those applications.
I did discover one odd thing in Fusion 360.
If I upload through the Data Panel command, then the upload fails.
If I upload throught the A360 Dashboard, the file uploads successfully. A 3D preview is generated so that I am able to view the file. There isn't anything too complex about the model itself as far as I can tell. Is there anything special about this particular file?
At this point, if I open Fusion 360 and look at the Data Panel, the solidworks file is listed there. I can right click on the SW file and select Create Fusion Design. Typically this will convert it into a design Fusion can use. However, this does not seem to produce any resutls! So it can be viewed, but not imported.
Are there any other examples of SW files failing to import?
I will escalate this issue to the development staff for further review and check back with you.
Nathan Chandler
Principal Specialist
