Announcements
Unable to thin extrude all lines from sketch
Lessy8TMLV
Lessy8TMLV
Hi guys
I have the following Problem in Fusion. I have a Sketch and I want to extrude all of the lines from the sketch. But some of the lines are not selectable and the whole area gets selected. And when selecting some lines, other, extruded ones just disappear.Does anybody know why that happens? I have done the exact same thing some days ago on an other project and it worked just fine. I can't figure out why it won't work in this Sketch. There is always some kind of error message. I think i'm making a stupid mistake, but I can't figure out what it is.
I am really not a pro in Fusion, so please excuse any stupid errors.
Help is apprechiated.
One of the attached files is the one I was successful and the other one is the one, where I can't get it to extrude all the lines. You can see what i mean in the video.
etfrench
You just need to select individual lines instead of profiles.
It's tedious because you need to set the same parameters each time.
ETFrench
Lessy8TMLV
Thanks very much for the answer. Do you mean I have to extrude every line after the other? The problem is that some of the lines are not selectable, only the profiles are, thats whats throwing me off. Or did I miss something?
etfrench
Yes, select then process each line.  I didn't find any lines that couldn't be selected.
ETFrench
Lessy8TMLV
Okay thank you very much, from now on I will extrude line by line. It's a bit more work, but at least it works that way.
I am still confused why it worked on the other Project, but whatever.
Thank you very much for your help.
etfrench
Sometimes you can add on to a selection.  It depends on whether or not endpoints are visible.
ETFrench
