Unable to rename/change appearance bodies
I'm currently creating a laser cut chess board out of PMMA. However I can only change the first layer.
The three bodies beneath the "board" itself i can't rename or change appearance, only with the default material or if i only change faces. When I try to rename the bodies it just changes it back to Body2/3/4 after half a second.
Another issue I encountered is when trying to render it: From below it looks good, but looking from the top the model is completely broken when I use a ground plane. Without it looks fine, the render is still terrible but thats probably the material properties.
I would really appreciate any help 🙂
