Unable to remove single edge from multiple fillet feature (bug!?)
4 REPLIES 4
edwinATABC
676 Views, 4 Replies
After creating different fillets on multiple edges in one single fillet feature, I tried to remove one, which results in all fillets becoming 0! This looks like a bug.
It used to be possible to remove one (or more) edges, by holding ctrl/command and selecting the edge.
Replicating:
Draw a box, click fillet, make 2 edges R1 and 2 other edges R2, finish
Now try to edit the fillet feature: hold ctrl and de-select one of the edges: immediately after de-selecting, ALL radii become 0 (and if you have multiple entries, they all become one)
Note: I run a Mac (in case it is relevant)
4 REPLIES 4
g-andresen
in reply to: edwinATABC
I think this topic was also covered here
günther
edwinATABC
in reply to: g-andresen
I didn't find that one, but yes, it is the same thing.
And it is worse when you have multiple radii, because then you cannot simple re-enter the radius, as it throws all radii on one heap...
Is there be a bug report somewhere, or should I make one? (don't know how this works with F360)
g-andresen
In that thread # 2 from
@jeff_strater
günther
edwinATABC
Ah thanks, now I see, I didn't scroll below the blank area, so I only saw the post itself.
