Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
UNable to launch Screencast ... can't launch from Fusion, crashes on startup
2 REPLIES 2
rumpelstielz
523 Views, 2 Replies
Hi, i have a problem which i wanted to document via screencast so i can post the question on the forums. Clicking on the Record button in Fusion does nothing so i tried to launch Screencast from the Applications folder but the application won't launch and i get an error dialog saying the application quit unexpectedly. Deleted prefs from Application support, trashed the app (v2.3) redownloaded the app (still at v2.3) but still quiting/crashing on launch.
what's going on ? how can i get this to work ? it used to work at some point ...
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
2 REPLIES 2
baribak
in reply to: rumpelstielz
Sorry to hear of your trouble.
Is the version of Fusion 360 downloaded from the Apple Store? Or from Autodesk.com?
Also, can you send the url where you are downloading Screencast from? I want to ensure I am using the same products from the same location as you to see if I can reproduce the issue.
Thanks for your patience.
Kevin Baribault
Fusion 360 Quality Assurance
rumpelstielz
in reply to: baribak
yes Fusion downloaded from Autodesk but that was a long time ago and there have been gazillion updates since, and screencast as well: https://knowledge.autodesk.com/community/screencast
