HI,
today i tryed to install the free trail of Fusion 360 but i had no sucess.
When i start the downloaded file it opens the streamer window and shows me the loading bar but after a few seconds it shows me the Error ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)
First i was thinking that the Firewall blocks the Streamer and i tryed it again with the FW turned off... ditn´t work.
Then i was thinking its might be the Router im connectet to it has a Firewall too but u cant turn it off, so i tryed installing it on my Laptop,that worked at the first try. but i cant use it on the Laptop, its way to slow.
What else can i try?
I attached the Logfile, hope that helps.
In hope of some Help, Hannes :´-(
