Unable to generate SECTION VIEWS
After Updating my fusion, I Can't make section views.
Please help to fix this BUG.
cmiller66
Hi supertechpune1,
What is happening at the point you took that screen capture?  Is the drawing hanging?  You should be able to hit Enter at that prompt and drag out your section view preview.  Can you close Fusion, restart and see if this repro's?  If it does with this design, does it happen with others or is it specific to this design?  We had no section view-related changes in the last update so I'm not sure what might be causing a problem here.
Chris
Thanks for your reply, i was pressing right click for selecting OK
Thank you
Supertech
