Unable to fillet BRep
rasmusfjordside
rasmusfjordside
Hi guys
I am unable to make a simple fillet on the lower edge of my BRep. The model was created by converting a quad mesh to T-Spline and I have modified the model in Fusion afterwards. I suspect that the extra edge (see attached image no. 2) is maybe causing the problem. I can share the file (or at least a cropped version of the model) but I will only do this in a private message as the model is the property of the design studio, where I work.
Thank you in advance
Rasmus Fjordside, industrial designer
TrippyLighting
I'd be happy to look at the model but I need to send ahead that as an Autodesk Expert Elite I am not an Autodesk employee but rather just a customer of Autodesk just as you are.
I general, filleting models created from either creased T-Splines or otherwise T-Spline based BRep models modified with conventional modeling techniques very often does not work. IF you use the Curvature Comb inspection tool it'll probably explain why a fillet is unlikely to work.
