Unable to edit sketch
barry9UDQ6
barry9UDQ6
I am working on a design that I am not able to share, and all of a sudden have a new problem.
I made some serious changes to my skeleton model which has resulted in some downstream failures, mainly sketches that have jumped around.
On this particular piece I have dragged the history marker back to repair the sketch.
As an example, if I RMB on the 1st sketch I get the option to edit sketch:
But for the second sketch, no option:
At no stage have I switched the timeline off. I must say this has never happened to me before..
HughesTooling
Notice it has the option to unsuppress, is that the reason you can't edit, it's suppress?
Mark Hughes
Owner, Hughes Tooling
barry9UDQ6
I wasn't able to find out, and I don't remember suppressing that sketch.
Trying to unsuppress  just locked my PC up. Ended up deleting and re-doing it.
HughesTooling
Just did a quick test on a simple design and suppressing a sketch does give the menu you see above.
This is what I see with a sketch suppressed.
If you are curious about the suppressed sketch you could open an older version of the design and check. I don't recall Fusion suppressing a sketch even after making quite big changes.
Mark
Mark Hughes
jeff_strater
the only situation where Fusion will suppress a sketch (or any feature) is if you suppressed something "upstream" that that sketch depends on for its sketch plane.  So, if you create an extrude, then sketch on a face of that extrude, then suppress that extrude, the sketch will become "indirectly suppressed".
Jeff Strater
Engineering Director
barry9UDQ6
Thanks Jeff, I think this is what happened.
Although what was confusing me is that I had dragged the history marker back, to in front of the upstream features.
So I was't expecting it to 'remember' the suppressed feature.
