Unable to delete Body5 object
dhevans79
dhevans79
Hi all,
I have the following project for a two-way toggle switch
https://a360.co/308fIx2
somewhere along the way, I have done something I'm not supposed to, and now I cannot delete the sphere "Body5".
The build log contains the following errors
Sketch15
1 Reference Failures
The sketch plane is lost, Cache is used. Please redefine the sketch to select other plane!
SpherePrimitive1
The body reference is lost, try editing this feature to reselect the lost body.
The primitive profile reference is lost.
If I redefine sketch plane, by right clicking on the sketch on the side menu, for Sketch15, this error goes away. but I cannot get rid of the SpherePrimative1 body reference error.
Can anyone help me and tell me how to delete this object.
Thanks in advance 🙂
etfrench
Both errors indicate why it's a bad idea to delete sketches or bodies that are referenced later in the Timeline.
@jeff_straterBody5 is read only and there doesn't appear to be any way to change it.
ETFrench
Beyondforce
Dear @dhevans79,
Knowing the difference between Delete and Remove is very crucial.
When you delete an object, you delete it completely from the timeline and the ONLY way to get it back, is from the cache by clicking on Redo right after the deletion.
If you deleted an object and restarted F360, you won't be able to get it back longer!
Which is why you must be VERY careful when you delete an object. You need to make sure that you are not using this object as a reference!
Which is also why it is best to use the Remove command because you are not removing the object from the Timeline entirely but only from future and you can always go back and restore it.
In your case, you don't have a chose but to recreate this model from the beginning. Please don't forget to follow R.U.L.E #1
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Fusion 360 Hardware Benchmark: TESREG.com
Visit us on Facebook Page Facebook community
YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
Beyondforce
Here is a video I have made about Delete vs Remove: https://youtu.be/LcdGX6f1Qb8
Ben Korez
| YouTube
jeff_strater
@dhevans79 - thanks for sharing the design.  I see the same thing - there is a Sculpt body that cannot be deleted.  The interesting thing here is that in a parametric design, there should never be a standalone Sculpt body - they should be hidden on exit from Sculpt.  So, we are very curious about how this occurred.  If you have any recollection of the history of this body, we would be very interested.  If you have old versions of the design that show this body in a more functional state, we'd be interested in that as well.  Thanks.
Jeff Strater
Engineering Director
MoshiurRashid
try to apply Remove command.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
dhevans79
Thanks for looking at the file. This was the first model I did in Fusion, so I have no idea how to recreate the issue. I was randomly clicking and adding/deleting objects to try to build my model. I was just trying to find a ball-type shape. I don't have any other versions of the file, so I can't help there either.
In any case, at least understanding why I can't delete it is lesson enough, and I'll try not to break it next time. I didn't manage to recreate the problem on my second model, so must be making progress 😉
