Unable to create a surface
sarik0031
sarik0031
 I am unable to create a surface, even after seleclting these curve and lines. I think the profile is closed too.  Please help.
I've linked my file. Check it if necessary
jhackney1972
You had a break in the indicated corner.  Model is attached.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
sarik0031
Thanks, Can you suggest me techinques or tools to identify breaks in such sketches?
davebYYPCU
It's called divide and conquer in previous postings here.
Draw temporary lines across the outline, see which side turn profile blue, and narrow down to the problem connection.
Might help...
sarik0031
Actually, in 3d Sketch it doesn't turns blue, if I'm not wrong.
davebYYPCU
Correct, (did not know the sketch was 3d)
so, second trick is to double click the outline, Fusion will chain select all connected items to the selected entity.
Might help...
