Ugly liquid rendering
kriomant
kriomant
I have created simple polygonal container and added liquid inside using "boundary fill".
Model looks like this:
I have assigned glass material to container and colored water to inner body. But when I try to render it, result is just ugly:
Test_liquid_render_2016-Sep-04_04-37-34AM-000_CustomizedView5468133728.pngf
What can I do to improve rendering?
donsmac
All you have to do is do a push/pull operation on all the surfaces of the liquid, except for the top surface. Push in by a fraction to give a bit of space between the glass and body. The problem is caused by the two objects sharing surfaces of geometry.
kriomant
Cool! It works! But is it a bug or not?
PhilProcarioJr
@kriomant
This topic has been discussed at length here:
https://forums.autodesk.com/t5/design-validate-document/colored-water-alcohol-amazingly-simple-manag...
Phil Procario Jr.
Owner, Laser & CNC Creations
kriomant
Ok, I have read that topic, now I understand why this happens. Until proper solution is implemented in Fusion, there are basically two workarounds:
1. Emulate liquid by splitting glass at liquid level and assigning material to inner faces
2. Shrinking liquid body
The quality of workaround 2 is fine for me. And it seems that Offset command in Patch env can be used to shrink liquid body automatically. Thank you!
