two possible bugs with SVG insert
cekuhnen
Mentor Mentor
cekuhnen
1. svg insert then selecting file does not do anything
2. svg insert in a new sketch shows the boundary box but now preview of the svg drawing file
https://drive.google.com/a/ckbrd.de/file/d/0Byzv_NlyKp_2VzJqQThjamRUdTQ/view?usp=drivesdk
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
sanjay_jayabal
Hi Claas,
Regarding item 1, when you select Insert SVG,
a) If you don't already have an active sketch, a new one is activated and it is waiting for you to select a plane to place the sketch on before the "Ok" command can be selected.  If you move your mouse in the graphics canvas, you should see a tooltip that asks you to select a plane or planar face.  Are you not seeing this?
b) If you are already in a sketch, then the "Ok" button lights up.
What do you think would make it more discoverable that the command is waiting for you to select a sketch plane?
best regards,
Sanjay Jayabal.
cekuhnen
@sanjay_jayabal
1. True I overlooked and was in the habit of other applications. However what I think contributed to my observation was I did not see the deign center and thus did not see the origin planes.
The dialog itself does not indicate anything. So maybe it might be good to also have a select origin value there so it is clear.
2. I think you miss understood me. What point is it to import SVG and have a scale function when I cannot see what I am importing and placing in Fusion.
The screen refresh rate in Fusion Sketch is really a serious issues and thus I tried to minimize manual move and adjust tasks after I placed the SVG file.
Thus I hoped during the import phase after I selected the file I would see a preview of the SVG file.
I know I mentioned it in other threads, but Fusions slow sketch engine screen refresh rate is becoming a dramatic issue in this application.
Today it rendered Fusion non-operational and I went back to Rhino.
Claas Kuhnen
