Trying to make a square Sheet metal cone
I have tried to make a square base cone, with no success converting to sheet metal, it is designed in surface then thickened, but does not create a flat pattern.
Can you please advise me on how to flat pattern this part.
Thank you.
carl.j.barker
Not a tangent chain.   Fillet this edge to the desired bend radius (approx 1 thickness)  after stiching and before thicken.not tang.PNG
g-andresen
hi,
take a look at this
and another one
günther
rushabhthakkar_910
https://youtu.be/sZLEYxyLXrw?t=505
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
TheCADWhisperer
Examine the Attached.
Post back for instructions on editing.
ritste20
Does anybody know if there are plans to expand the sheet metal toolset in Fusion? When I started to dig into this I realized how much I missed having the Inventor tools.
Also, I think the OP was trying to do a single body sheet metal part which wouldn't be possible with the corner geometry at the radiused flange. So @TheCADWhisperer four individual panels was the best solution I could come up with as well in terms of manufacturability. Nice example!
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
