The cd holer I am making is the center part that holds the CD by the middle hole. Imagine a PS1 or a Discman from back in the 2000's. It is a small piece that consists of a flat cylinder 2 mm tall, which will support the CD, and another one on top 4 mm tall with a 2mm chamfer. On the periphery of the chamfered cylinder there have to be some spherecal "bumbps". These "bumps" allow the CD to stay in place when insterted and the have to leave enough room for the CD's thickness which is 1.2 mm. Since this is a 3D printed part I need to make many adjustments which are mostly on the middle 4 mm tall cylinder's diameter. My question is how can I make the spheres dependent on the 4mm tall cylinder's dimensions so that the bumps are always on the face of the cylinder allowing me to not having to move them every iteration I make. I attach images that may help understand. Thanks for the help.
