Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Trying to make a parametric cd holder. Help needed
JuanDAyalde
JuanDAyalde
The cd holer I am making is the center part that holds the CD by the middle hole. Imagine a PS1 or a Discman from back in the 2000's. It is a small piece that consists of a flat cylinder 2 mm tall, which will support the CD, and another one on top 4 mm tall with a 2mm chamfer. On the periphery of the chamfered cylinder there have to be some spherecal "bumbps". These "bumps" allow the CD to stay in place when insterted and the have to leave enough room for the CD's thickness which is 1.2 mm. Since this is a 3D printed part I need to make many adjustments which are mostly on the middle 4 mm tall cylinder's diameter. My question is how can I make the spheres dependent on the 4mm tall cylinder's dimensions so that the bumps are always on the face of the cylinder allowing me to not having to move them every iteration I make. I attach images that may help understand. Thanks for the help.
jhackney1972
You need to attach your model for the Forum users to help.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
JuanDAyalde
Done!
jhackney1972
All you are asking for is to keep the 4 balls located, by their center, on the edger of the spindle diameter as you change this diameter.  This model will do that.  You have one Parameter in the Parameter table to change to make it work.  Model is attached.
By the way, avoid using Primitives (spheres in your case), as they cannot be used in dynamic parameter work.
JuanDAyalde
That is just what I needed John, thanks. May I ask how you did it? I am checking the file and I can see that you have a plane which I am assuming was used for the making of the sphere, using an arc and then a revolve...? How did you make the sphere be on the edge of the 4mm tall cylinder? Thanks in advance
jhackney1972
After creating the Construction plane on the top edge of the spindle hub, I created a sketch on that plane.  Into this sketch I projected the hub diameter.  This sketch is linked to the hub diameter so it moves with the parameter change.  On the same sketch I added a circle bisected with a line which creates an accurate half arc profile which is then used to create a sphere using the Revolve command.  Last I patterned the spheres.
Since the center of the circles, for the spheres, is constrained to the projected circle, they move with the circle as the hub diameter changes.
If this fully answers you question, please select Accept Solution on my posts.  If you need further help please ask.
JuanDAyalde
Thanks a lot John, you have been very helpful, and I have learned several things. First, that I can make a plane to make a sketch on it and also that I can project stuff on said plane to use as base for other sketches, in this case the 14 mm diameter projection/spheres. Cheers!
