Trying to Find Expression for Component Height
jackG933P
Message 1 of 13
jackG933P
As the title says, I am looking for a way to use the height of a component in a parameter expression. The component I need to find the height of is one that I swap in and out and changes all the time. I need a way to drive other dimensions using the bounding height of that particular component. In other words, I want to input a variable into the expression like "Mycomponent.height + 3" for example.
Is there a way to do this currently in fusion 360?
Replies (12)
Message 2 of 13
Beyondforce
Hey @jackG933P ,
If I understand your question correctly, then the answer is YES.
You can create a User Parameter and call it "Mycomponent.height". Then anytime you want, you can call it and use it in any math equation you want, like "Mycomponent.height + 3".
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
Message 3 of 13
jackG933P
That is not quite what I am asking, Ben. I am looking for a variable built in to Fusion that has the value of the bounding box of a component or model.
I am importing a component that already has all of its dimensions set. I am trying to then drive the values of other dimensions on other components by using parameter expressions. For example, I import a component that is 3 inches in height. A different component already in the design then adjusts the values of its joints to accommodate the 3 inch tall component I just imported.
Message 4 of 13
Beyondforce
Ok, now I understand. Yes, you can do that with the "Derive" command.
You can use it to Import or Export a component, and you can choose to take anything with it including the User Parameters.
Here is a video on how it works, but I'm also planning on making a video on the "Derive" command for my YouTube channel as well very soon (Fusion 360: NewbiesPlus):
http://help.autodesk.com/view/fusion360/ENU/?caas=caas/video/youtube/watch-v--tYCfuaagX4.html
Ben Korez
| YouTube
Message 5 of 13
jackG933P
I can see how that would work if you already had a parameter to reference, but the step files I import do not have any. I need to be able to pull the bounding box property values from the component alone.
Message 6 of 13
Beyondforce
Well, you can do that using the Dimension tool or the Project tool depends on the situation or the end result.
Ben Korez
| YouTube
Message 7 of 13
etfrench
You could probably do that using the API.
Also look at the Inspect/Interference tool.  You could place blocks a certain positions, then use the tool to see if the inserted part has a positive interference result.
ETFrench
Message 8 of 13
lichtzeichenanlage
How should this work at all? The existing component can't have a reference to components that might exist at any point in time. And what happens if you have 10 components.. how should a parameter know if it's relevant or not? This doesn't makes sense for me.
Message 9 of 13
laughingcreek
Some programs will produce a bounding box around an object and show what the dims are.  fusion doesn't do this.  My understanding is the OP would like some way to assign a value returned from a bounding box to a user parameter.  The only way I see to do this is either a manual process, or writing a script through the API.  Basicly,  as it stands today, fusion doesn't allow the use of driven dimensions.
Message 10 of 13
lichtzeichenanlage
My understanding is, that the TO wants, that a newly imported / inserted
component automatically changes values of existing components...
Message 11 of 13
jackG933P
What I am doing is importing a component and then placing it into an already existing component that is a "container". The bounding dimensions of this "container" component change with each new imported component and I would like a way to reference those dimensions in a parameter expression.
Message 12 of 13
etfrench
Without knowing what the size range of the components and containers, it's hard to give a specific answer.  Is there just a few standard shapes or hundreds?  What are the tolerances? Is it just the height that changes?
ETFrench
Message 13 of 13
jackG933P
Thank you to everyone who posted. I will accept this as the solution. I'm going to look into doing what I want through the API.
