I'm trying to create a stand for a piece of abstract art. I filled a box with clay and used the piece of art to make an imprint in the clay, i used a camera to get a scan and uploaded the obj file into fusion. From there i used mesh tools to define faces and delete areas i didn't need. I was left with a fairly perfect negative imprint of my piece . I want to take that shape and use it to cut a hole in the top of a 35mm x 35mm x 35mm box and than 3d print the file as a stand. I don't know if this is possible can anyone guide me to a tutorial on how to do this I'm fairly new to the software
I sure can... Thank you for trying to help I appreciate it...
This is what I have so far, as you can see when you open the file its just an imprint of a corner that is irregularly shaped and I want to use it to make a cut out in a 3d printed base.
I was thinking I could also make my square base, move the mesh file into the base, place it just below the surface, and then make a hole in the base exposing the mesh shape, save it as an stl and than try to print
Hi @elibrandi2014, There maybe other ways to do this easier but the first thing I thought of was that toolpaths can be driven by a mesh surface and in the manufacturing tab we can save out a stock model after it has been simulated. Take a look at my screencast to see what I did. I did have to make the tool super long, and once the simulation ended I right click to save out the model. At the end I'm adjusting the stock size so that there is less of a vertical wall at the edge of the part.
incase your tempted, I would suggest avoiding any workflows that involve converting a mesh like this to a brep. keep it a mesh and work with meshes instead. attached is an approach using just fusion. but you can get more control over your results if you use mesh mixer, there are a lot of tools available there that aren't available in fusion.
