Trouble with Built-As Joints
I have 5 different components, all in place, in Fusion 360.
I applied as-built joints to all. The all 'wiggled' to show the joint was made.
But when I try 'move/copy' to the whole assembly, only the selected component moves - not the whole assembly. I am new to this, but understood that as as-built joints were effectively glue that held components together.
Any help would be appreciated
Kevin
oops - wrong forum - this is not CAM .....
TrippyLighting
It might be possible that you are moving bodies, rather than components, depending on on how you slected the objects,
