I created a sketch, I projected the geometry. I sketch an outer box. I tried to select the projected geometry but i was only able to select one of the lines. I traced the projected lines and tried again, i could only select one line. I tried ctrl select and alt select no luck. What to I have to do.
See attached file component Latch lever:1 subcomponent lever pad:1 Sketch 1. I am trying to select the inner quadrilateral with an arc.
What am i doing wrong
