Trouble inputting min max and rest positions on slider joint
It worked yesterday, but today after update I cannot input data into the slider joint edit boxes. I can, but when I move to the next one, the data previously entered is lost.
The two images show what I mean. You can see the -.35 dimension reverted to -1 when I started inputting the max data input.
Beyondforce
Hi @Anonymous,
That seems like an odd problem.
If you don't mind, I can test it in my PC.
Cheers / Ben
Check out my video channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
daniel_lyall
@Anonymous it happens sometime Lee if you keep hammering away at it it does work, it a real pain your youtube vid looks good
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Beyondforce
Talking about my Vids? Thanks @daniel_lyall 🙂
Ben Korez
| YouTube
daniel_lyall
@Beyondforce No lee's new one on his youtube channel, I comment directly on your vid's on your channel
Daniel Lyall
The Big Boss
Mach3 User
Thanks Guys.
Messing with it did seem to work. What I did was just reverse the dimensions I was going to use for min and max.
I don't mind sharing that file with you, but since I did get it working, not sure it would show up again.
daniel_lyall
@Anonymous I have that problem come up from time to time it is a bug last night was 20 goes for it to take then the next joint worked first time.
Daniel Lyall
The Big Boss
Mach3 User
