Trouble in modelling chain
Hi everyone,
                     I'm trying to model a chain conveyor belt and i'm having trouble with roller chain.
1. when i insert a chain Only a small section is getting added. I'm coping that section to make the whole chain( I don't know if its the right method)
2. I can't define a proper joint between the sprocket and the chain which will give the proper motion between the chain and the sprocket.
how can i solve this?
Can someone help me with this?
Thanks in advance 😇
Hydra9059
Can you share an image or screencast of your design showing your problem? For adding a relation between the sprocket and chain mate relation is more applicable than joints
Student Ambassador Silver
