I am trying to import a DXF into Fusion and the importer isn't even letting me click "OK".
I start with a DXF that looks like this (as viewed from Autodesk Viewer online).
And when I go to Fusion to import it, I choose the "insert DXF" function under the Insert tab. I select a plane and then select the file on my computer but then Fusion won't let me insert it. It doesn't even acknowledge I selected a file.
Attached is the file below. I also tried uploaded it as a file and opening the file and Fusion let me do it but doesn't show anything in the file.
Thanks for your help!
