Trouble editing a spline
djlunty
Message 1 of 8
djlunty
I have drawn a fit point spline and can't edit the points or or the tangent handles.  I don't know what I did to cause this problem as I have other files that I can edit splines in.  The spline that I can not edit is in "Sketch 1" in "stand extension".
Also when editing the tangent handles for splines is there a way from stopping them from being changed symmetrically?  Change the length of the each end of the tangent handle a different amount?
Doug
Replies (7)
Message 2 of 8
TheCADWhisperer
@djlunty
Not sure what is going on here,
I am not able to click and drag the points, but I am able to edit by dimensioning location and magnitude/angle of the point handles.
Message 3 of 8
HughesTooling
Seems like these 2 tangent constraints are causing the problem but I don't know why.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
HughesTooling
Doug
No. The only way in Fusion is to use 2 splines. I know some programs allow non symmetrical handles but if you import an SVG with non symmetrical handles it gets split into 2 splines.
Mark Hughes
Message 5 of 8
djlunty
@TheCADWhisperer
Weird that the spline can only be adjusted by inputting distances rather than dragging points.
@HughesTooling
Also weird that the tangents that you identified as a possible problem are not part of the splines
Could not figure out the problem so just redrew as tangent arcs.  Splines seem to be a bit finicky from time to time.  This is not the first time I have had this problem.
Thank you both for having a look.
Doug
Message 6 of 8
djlunty
@TheCADWhisperer
@HughesTooling
The problem was the two coincident constraints where the splines touched a previously drawn curve.  The constraints would have been created when I trimmed the linework between the two splines.  Removing the constraints allowed the splines to be edited by dragging the spline points.
Doug
Message 7 of 8
laughingcreek
@Phil.E - this looks like one of several seeming related spline bugs that have been floating around since time immemorial.  my guess is they're not even on the sketch teams radar anymore.
Message 8 of 8
Phil.E
@laughingcreek The problem is the same as reported in FUS-64376 by @jeff_strater a couple years ago, I guess that's a little bit immemorial 😁. When fit point splines are coincident with projected geometry like this, it creates this condition. The sketch team has the ticket open, I just added more notes and asked them to look at it again.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
