I'm having trouble with a chamfer toolpath. I've attached my .f3d file here.
The upper two chamfers give a warning (no passes to link), but appear to simulate fine. I can't seem to get the lower chamfer to calculate, despite playing around with the chamfer tool offset and clearance. I've tried setting the offset to a few thousandths less than the maximum length of the flutes, with zero clearance, but even then I can't get it to produce a toolpath.
I'm sure it's because the fillet extends very close to the edge of the part, and would likely be violated by even a small chamfer. I could redesign the part to have a smaller fillet, but in the interest of trying to learn: is there a way to force the chamfer to cut?
Thanks in advance
Lee
