Triangular support rib design
otis_d
otis_d
Hi, I'm trying to make a triangular shape rib/support that would connect a cylindrical object to a horizontal plane. Any suggestions on the workflow? For some reason, I'm having a hard time making it work.
laughingcreek
a possibility-
otis_d
Thanks a lot,  the loft command... duh
m.sachin.krishna
Autodesk Support
Autodesk Support
You can also use the rib command and a sketch line like this. You might have to flip the direction sometimes.
Sachin Krishna
Fusion 360 Product Support
m.sachin.krishna
Autodesk Support
Autodesk Support
Also, just realized that you were going for a different shape. My suggestion is for a plane rib.
Sachin Krishna
