Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Transparent acrylic rendering
6 REPLIES 6
3532 Views, 6 Replies
I am trying to render an acrylic cube but for some reasons, the result is not good.
I am attaching the render and my setup for material and environment.
As you can see there is a line in the render which I am not sure why! I tried to rotate it 90 degrees but the result was same.
Anyone have any suggestions?
Thank you.
Sasan
Screen Shot 2017-10-05 at 3.36.45 PM.pngScreen Shot 2017-10-05 at 3.37.09 PM.pngScreen Shot 2017-10-05 at 3.37.30 PM.png
6 REPLIES 6
Oceanconcepts
Are you talking about the reflections you see from your environment settings?
- Ron
Mostly Mac- currently M1 MacBook Pro
in reply to: Oceanconcepts
I am not sure where is come from, but I tried with different environment and the result was same.
If you see there is a horizontal line on the right face of the cube; above is frosted and below is clear!
Any thought?!
Thank you,
Sasan
TrippyLighting
NO natural object has perfectly flat faces with infinitely sharp corners. So allow an old guideline and bevel your edges or in other words put fillets on the object, or a chamfer and then a few micro fillets.
Also, don't use any of the studios environments in Fusion 360 for lighting. Use one of the sunny outdoor scenes, or indoor scene with lots of small, high power light sources.
in reply to: TrippyLighting
I have the same problem.
I have try the solution fillets every edges, but I still got this.1c82dc16-80be-41b8-8e24-65c0923b8ba3.PNG
can any one help me ?
thanks
TrippyLighting
You did not read the second part of my answer, didn't you ?
That acrylic has to have a more interesting environment to reflect and refract something.
I got it !
Thank you very much!
