Toolbar problem
Toolbar problem
hato54
Toolbar problem
hato54
Some times it's impossible to jump from CAM to MODEL or PATCH and back to CAM again.
If I use the right mouse button and choose Workspace and the Cam and the Model again it allways works,
jeff.pek
Hi -
Can you describe the situation in a little more detail?
What does it mean that it's impossible to jump back and forth between the workspaces?
Does this mean that when you click the other workspace in the dropdown menu, nothing happens?
I wonder if the application log has anything interesting...
See %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\<userId>\AppLogFile<datetime>.log
  Jeff
hato54
Hi
"What does it mean that it's impossible to jump back and forth between the
workspaces?"
Yes, nothing happens, I was working in the CAM environment had to jump to
the MODEL and then PATCH and back to CAM.
I had still CAM problems so I had to jump back to PATCH. After jumping a
couple of times between CAM and PATCH nothing happens when a click the
toolbar "CAM" or "PATCH" or "ANIMATION" or ""MODEL".
The toolbar wont change and so also the environment.
I attached the logfile
Best regards
/Håkan
Best regarda
Håkan Torén
WishTech
Lille Långenvägen 12
441 63 ALINGSÅS
SWEDEN
mob. +46708501310
www.wishtech.se
jeff.pek
Thanks for the information.
I'm not seeing an attachment here. Do you see it?
If you did actually attach it, and for some reason it's not showing up here, could you e-mail it to me?
I'm at jeff DOT pek AT autodesk DOT com.
Jeff
visticb
Hi
Does the workspace dropdown hide after you click it?  Does the workspace dropdown show again when you hover over the current workspace button?
Could you made a video showing the problem?
Bob
hato54
Hi
Now i can't repeat the problem.
I'll download Screencast so I can use it next time.
Thank You for You interest i my problems,
Best regards
Håkan
Håkan Torén
WishTech
441 63 ALINGSÅS
SWEDEN
mob. +46708501310
www.wishtech.se
